Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Apelson Oven | AOMM60SS | Thermostat Stuck ON
- This topic has 10 replies, 3 voices, and was last updated 7 years, 7 months ago by
WhiteGoodsMatter.
August 30, 2018 at 4:55 pm #94545
WhiteGoodsMatter
ParticipantHi there!
Fairly self-explanatory but the orange light (signifying the heating element is on) is always lit whereas prior to the fault this would only light when the temperature gauge was NOT zero.
Fault discovered when i thought i was cooking my dinner at 170 degrees but actually the temperature was 270+ (used a food probe thermometer which i stuck through a small crack in door opening)
How should i go about diagnosing the fault please? I’m heading our now to by a multimeter 😉
August 30, 2018 at 9:16 pm #457633electrofix
ModeratorRe: Apelson Oven | AOMM60SS | Thermostat Stuck ON
got to be a thermostat failure
August 31, 2018 at 10:05 pm #457634WhiteGoodsMatter
ParticipantRe: Apelson Oven | AOMM60SS | Thermostat Stuck ON
Thanks Dave. Is there any way for me to test this using my new multimeter?
August 31, 2018 at 10:16 pm #457635WhiteGoodsMatter
Also the missus is freaking out because of the browning at the rear (see image). I reckon its just burned oily/fatty residue that escaped from the oven chamber at the gaps where the oven light, element and thermostats enter it. Would very much appreciate your opinion though as I havn’t seen the backs of m(any) ovens!
August 31, 2018 at 11:36 pm #457636electrofix
no panic its normal. fibreglass cannot burn
as for the thermostat
its simply a switch that’s controlled by temperature. you can put your multimeter on it but all that will tell you is whether its on or off and not if it is responding to temperature
if you turn the temperature to off the oven should not heat. If you then set it to 50 degrees and it goes above that then it needs changingDave
September 1, 2018 at 10:13 am #457637WhiteGoodsMatter
Thanks for the quick reply Dave. Pity you guys don’t stock the part or would have ordered from here. Do you have a way I can donate?
September 1, 2018 at 10:23 am #457638don
WhiteGoodsMatter wrote:Thanks for the quick reply Dave. Pity you guys don’t stock the part or would have ordered from here. Do you have a way I can donate?
You can try our own shop send an email to spares@ukwhitegoods.co.uk or hit the “shop now” green tab on the right.
Don
September 1, 2018 at 10:30 am #457639electrofix
no we dont take donations
but
from my point of view, if you would like to make a donation to any cancer charity for the help given, that would please me
I am fairly sure admin will have no objection to thisDave
September 1, 2018 at 10:59 am #457640don
electrofix wrote:if you would like to make a donation to any cancer charity for the help given, that would please me
Good shout Dave 🙂
Don
September 2, 2018 at 2:17 pm #457641WhiteGoodsMatter
Thanks guys. Tried searching the store but couldn’t find anything listed under Apelson (that’s before I even put in a model number). Only place i could find it stocked was here. £5 just sent to Cancer Research, thanks :tup:
September 2, 2018 at 9:25 pm #457642electrofix
“£5 just sent to Cancer Research, thanks :tup:”
thanks
