Hi there!
I have one of these fridges and over the last couple of days it has started to make quite a racket! It sounds like a motor type noise and stops when the door is open completely. If you close the door, the noise gets louder, or if you put weight on the front of the compartment where the salad tray goes in, it gets louder. The noise will eventually stop after a few minutes once the door is shut.
Any suggestions????? 😕
Thanks kindly
Bex
