APM 6825 Fridge Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum APM 6825 Fridge Freezer
  • #20512
    dhilton
    Can anyone help? I have just moved house and my APM 6825 integrated fridge freezer (I believe it was from MFI) is not freezing properly.When I turn on fast freeze the items in freezer start to defrost, after freezer has been on for a few weeks there is a ice built up by vents located behind 3rd drawer, there doesn’t seem to be any cold air flowing from right vent behind top drawer. Freezer will keep things frozen when they are already frozen but if for example i put in water for ice cubes it can take days to freeze. Fridge seems fine. Is it worthwhile getting engineer out or should I just replace.
    If anyone can help you might save my sanity
    Debbie
    #187308
    Re: APM 6825 Fridge Freezer
    Does the freezer door (not the decor door) actually fully close? They often move slightly in the housing and the decor door, whilst appearing fully closed, is holding the freezer door slightly open. Damaged door seal can cause a similar effect.
    Is there ventilation to the unit – the ability to draw air in easily is crucial to the machines operation.
    HTH,
    dhilton
    Penguin45 wrote:Does the freezer door (not the decor door) actually fully close? They often move slightly in the housing and the decor door, whilst appearing fully closed, is holding the freezer door slightly open. Damaged door seal can cause a similar effect.
    HTH,
    Hi, Have removed kitchen door and freezer seal does seem intact and sealed all around- any other ideas?
    #187310
    expertcat
    sounds like a defrost problem.
    Worth an engineers call.
    To find your nearest engineer on whitegoods go to repair@ section.
