The door seal on my washing macine needs replacing. The only product number of the washing machine I can find is in the handbook and it is APM8522, model number APME.
Does anyone know which door seal I need to order to replace the exsisting one?
An APM8522 is pretty easy from memory and it should be a stock item, email to spares@ukwhitegoods.co.uk should sort that out and, again from memory, they’re about £13-15 plus VAT.
This is a Merloni built machine; if you can let Jesse know whether it is a washer or a washer dryer AND whether there is a vent hole in the bottom of the gasket (Lift the pleat in the seal at the six o’clock position and see if there’s a hole or not) we should be able to supply you.
