APM 8552 (for penguin)
Viewing 1 post (of 1 total)
  • #47181
    helitubby
    Penguin, Thanks for info previously about the pcb and my drum not spinning.
    Set to ‘5’ and worked as normal for main part of cycle.
    Pump noise started near to end of 1st cycle, machine kept spinning and drained. Clicked onto ‘B’ cycle and filled again.
    The machine is still working through all the cycles but the noise is present. Will the pcb board still be the problem. No problem with the contacts or tesion on belt.
    My drain filter was totally blocked, I have checked pipes, they are ok.
    Thanks for help, Helitubby
