Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › APM 8702 Washer/Drier with Pics.
- This topic has 13 replies, 2 voices, and was last updated 18 years, 7 months ago by
Drowned-Rat.
September 10, 2007 at 6:48 pm #30441
Drowned-Rat
ParticipantHi there, I have an APM 8702 combined washer drier which suddenly decided to turn our kitchen into a swimming pool 😥
By looking through previous posts have narrowed it down to the pressure switch, having checked all hoses for blockages I noticed the gray wire [see attached pics] was disconnected.
When machine starts its cycle no water enters the machine until I disconnect this gray wire, leaving it off overflows the washer :taz:Can I assume that the switch itself is faulty, and if it has gone where can I get the part number and a replacement.
Im in Scotland, ML7 5RB, Harthill, near Bathgate.
Thanks in advance 😀
The Rat.September 10, 2007 at 7:23 pm #227211Penguin45
ParticipantRe: APM 8702 Washer/Drier with Pics.
Dodgy switch sounds good to me………
P/no 520004600 – an email to spares@ukwhitegoods.co.uk for prices and ordering.
The Penguin.
September 10, 2007 at 7:36 pm #227212Drowned-Rat
Thanks penguin :salute:
Dont know how the wire became loose, but seems funny that it doesnt work when reconnected.
Gray wires do go together dont they ??
Cheers
The Rat.
September 10, 2007 at 7:55 pm #227213Penguin45
Two greys go together.
Have you tested the switch to see if it does the “clicky” thing?
September 10, 2007 at 8:02 pm #227214Drowned-Rat
Have taken switch off, blowing and sucking on it makes the correct noises, as in pressure on, pressure off.
Can it be electrically tested off the machine ??
The Rat.
September 10, 2007 at 8:41 pm #227215Penguin45
The three tags in a line are a make and break switch – one tag is common. The tag in the middle is the flood protection over-ride, which needs an “overblow” to make its connection.
September 10, 2007 at 10:07 pm #227216Drowned-Rat
Have just put it all back together and it seems fine again :tup:
Thanks for your help Penguin :worthy:
The Rat.
September 10, 2007 at 11:36 pm #227217Penguin45
I would replace the pressure switch anyway – they can become “sticky” in operation – they can also carbonise internally, allowing strange electrical pathways………
September 11, 2007 at 4:21 am #227218Drowned-Rat
Im going to replace it as you have advised :tup:
The Rat.
October 15, 2007 at 5:31 pm #227219Drowned-Rat
Can anyone tell me what screws adjust what on the pressure switch :conf:
Cheerz 🙂
The Rat.
October 15, 2007 at 8:45 pm #227220Penguin45
No – do not attempt to adjust the pressure switch………
What’s the problem now?
October 15, 2007 at 9:08 pm #227221Drowned-Rat
No probs m8, just wondered why they were there and what controlled what.
Just for reference 😉The Rat.
p.s. machine running smoothly again after changing the switch, had to wait a bit tho thanks to our “friends at royal mail” 😡
Spent a few weekends in front of the machine manually switching wires, which I dont recommend to anyone :zap:
October 15, 2007 at 9:11 pm #227222Penguin45
They control the “tipping point” for the lever switches inside – the setting is crucial for correct operation, so often there is a blob of paint to seal the unit.
Glad you got there,
Penguin45.October 15, 2007 at 9:15 pm #227223Drowned-Rat
Your a top dog !! Penguin !! LOL.
Thanks again !!
The Rat.
