APM6321 larder fridge does not get cold enough – any suggest
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum APM6321 larder fridge does not get cold enough – any suggest
  • #49105
    nottstom
    I have a APM6321 Larder fridge built inot my kitchen alongside the freezer APM6222, the fridge is not cold enough even when I set the thermostat to 5 food is not lasting very long. I have put a thermometer in which varies between just being in the acceptable range for a fridge and being too warm. The fridge has lots of clearance around the vent for air circulation and the drain hole is clear under the salad crispers. Any ideas on what to check next and how to check it?
    #298770
    spimps
    Re: APM6321 larder fridge does not get cold enough – any sug
    If it’s more than 2 years old the condenser which is underneath could be blocked.
    Will mean taking off the plinth and the plastic kick board covering the vents,you may then see fluff etc.Best to pull it completely out of it;s fitment and then you can also check if the motor is running constantly then you could have a refrigerant leak,or a faulty compressor.
    Switch off first
