apm6855-1
  • #74731
    senseib
    This f/f is displaying the fault code H can anyone tell me what this is ?
    Thanks,
    Brian
    #392678
    Re: apm6855-1
    H = High
    Temp probe probs……maybe?
    #392679
    senseib
    Re: apm6855-1
    Hi Martin,
    Thanks for your reply, do you know where to look for the temperature probe on the f/f as this is an integrated appliance ?
    #392680
    Re: apm6855-1
    Sorry no. 🙁
    #392681
    SAMURI
    Re: apm6855-1
    On the APM6855-1 it is more likely a fan fault as it has the newer round probe fitted.
    On the APM6855-0 it had a flat probe ( no frost evaporator sensor ) and was a common fault.
    The sensor and the fan are fitted behind the rear panel in the freezer.
    The fan stops when you open the fridge door and on the early APM6855-1 also stops when you open the freezer door.
    You can operate the door sensors with a magnet to test the fan.
    Bob
