Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › APM6855 fridge temp – again!
- This topic has 6 replies, 3 voices, and was last updated 16 years, 10 months ago by
Buttons.
June 5, 2009 at 10:00 am #46221
Buttons
ParticipantI’ve endured this for ages, usual problem: fridge temp going up, temporarily sorted by defrosting fridge/freezer for 48 hours (24 hours in warm weather when my kitchen warms up!).
Used to happen every few months, then about every month, now it’s down to two weeks, so is getting far worse!
Does this point to a DEFINITE part fault? I mean, I understand that this can be caused by the fan, thermistor, etc but does this worsening of the problem indicate for definite that it is, say, the thermistor?
If it is that, is this the right thermistor to replace the existing one with:
http://www.partmaster.co.uk/cgi-bin/pro … 1184:67622
Also, haven’t looked at the back yet, but how ‘easy’ is it to access once I pull out the fridge freezer and get to the back of the unit?
Thanks. 🙂
June 6, 2009 at 6:25 pm #288594Buttons
ParticipantRe: APM6855 fridge temp – again!
Help?
Please?
June 6, 2009 at 6:33 pm #288595Simon46
Only a multimeter will tell the condition of the parts out of circuit.
Power off if you are going in.S.
June 8, 2009 at 10:00 am #288596Buttons
I guess the only way to access it is through the back? There’s no hidden panels inside that will save me having to drag out the (fitted) unit? I don’t mind doing that to fit the part, just trying to avoid it ‘just’ for testing, only to have to push it back in (a tricky job!) then pull it back out again to fit the part. 🙂
BTW, is the part I linked to going to be the correct type if the original is indeed faulty?
June 8, 2009 at 8:07 pm #288597spimps
Pointless buying spares before you ascertain whats faulty.
Could be,defrost heater which needs a meter to check.
Easy to go in from the front of the freezer as all is behind false back in freezer,thermistors and thermal cut outs are in there too.
SWITCH OFF AND UNPLUG FIRST !!June 8, 2009 at 8:13 pm #288598Buttons
Thanks. So how do you remove the false back from the front of the unit?
Is it in the fridge or freezer compartment?
June 8, 2009 at 8:34 pm #288599spimps
Take out the food and look for screws holding the plastic back liner,possibly 6 or 8 usually.
It will then pull forward,if there is frost around you may have to use a hairdryer to warm up and free the back,there may be also a 2″ thick piece of insulation behind the back.You should then see the evaporator assembly and it’s compnents.
Switch off and unplug first. -
