APM8513 i/a/w
  • #30301
    Built in Merloni jobbie. Set timer, switch on,door locks, relays click on PCB and everything happens – except for motor action.
    We have a circuit through the motor and the loom. We have a circuit off the board through the motor. Heater is fine. Subbed in replacement board with no difference.
    What am I missing?
    Thanks,
    NWAR
    Re: APM8513 i/a/w
    We’ve been to a few the same and changing the PCB has fixed them – 546021400
    On the previous version you wouldn’t get anything after the door lock with a PCB fault but on these new ones we’ve seen them fill/drain/heat ok when the board goes.
    #226701
    Re: APM8513 i/a/w
    All right, my learned friends………
    I have:
    1/ Continuity tested every wire in the machine
    2/ Fitted one of EMWs’ finest recon modules further to NWARs comment
    3/ Fitted my spare timer (Hey – it’s Sunday, I’ve got time 🙁 )
    4/ Subbed in my spare motor
    5/ Infinite earth reading on the heater
    And it still won’t run the motor.
    I’m disinclined to believe in two duff modules (never had a duff one from EMW), so anything I’m missing here? Or shall I just send for the trebuchet?
    Re: APM8513 i/a/w
    Is this machine made by Antonio Merloni or the Indesit mob?
    Re: APM8513 i/a/w
    One of Toni’s……
    Finished up new timer and recon pcb.
    Re: APM8513 i/a/w
    I’m glad I passed on the one that phoned me today then. :rolls: 8)
    #226705
    Re: APM8513 i/a/w
    Good call……. 😀
