APM8521 (Servis) 800 spin spider bolts/rivets/fixings?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries APM8521 (Servis) 800 spin spider bolts/rivets/fixings?
  • #44998
    I’m going to do this tomorrow if Citylink are as reliable as they usually are. It’s one of those thin 4 legged spiders as used on some old Bendix etc.
    Not done one of these before. I suspect the old one may be held on with solid rivets or something? Anyone know what bolts I’ll be best to take along and are the old rivets a pain to get out?
    Mike.
    Edit: Sorry, meant to post in Technical Enquiries if there’s a mod around?
    #283242
    Re: APM8521 (Servis) 800 spin spider bolts/rivets/fixings?
    8 x M6/24mm, washers and nylocks. Easy peasy.
    (Moved, passing Mod around…. 😀 )
    #283243
    Brilliant. Just what I needed to know! (Though I’ll believe the easy bit when it’s done and dusted.)
    Cheers Chris,
    Mike.
    #283244
    leavemetogetonwithit wrote:(Though I’ll believe the easy bit when it’s done and dusted.)
    Angle grinder, then the drill……. 😆
    “It’s real engineering, Mrs!”
