APP 6302 problems
  • #38059
    bigyin
    Hi folks,
    I have an integrated Schreiber APP 6302 Larder.
    I recently replaced the lower left door hinge.
    The problem now is the door doesnt stay shut, well it does but the slightest tug and it opens. A couple of times I’ve found the door sitting open.
    The hinges look fine, it’s like the magnetism of the door seal has weakened and is not holding the door shut. Is this the problem.
    I’ve read elsewhere on the forum that a new door can be purchased.
    Another thing I’ve noticed is the bottom of the larder fills up with stagnant water (ugh). Whats causing this to happen.
    Is it worth fixing or is it time for a new unit ?
    Any advice appreciated…. thanks
    #257568
    gegsy
    Re: APP 6302 problems
    I would have replaced both hinges as they generally wear evenly TBH.
    Most likely other hinge pulling door ajar.
    As for stagnant water, I would check that the drain hole at the bottom rear of the fridge wall isn’t clogged at top and bottom.
    bigyin
    Ok thanks for reply.
    How do i check for clogged drain hole ?
    and there seems to be a hell of a lot of water, where does it come from / go to ?
    #257570
    gegsy
    You will need to “rod” the hole in question with something like, say a pipecleaner or equivalent at the fridge end; and then check that its clear at the drain end above compressor at rear.
    HTH
    bigyin
    ok I’ll give it a go. It must be blocked since the water is there.
    #257572
    gegsy
    Yup, it all drains down to bath above compressor/motor and the heat of that evaporates it away 😀
    bigyin
    and you think I need a new top hinge rather than replacing the seal to keep the door shut.
    #257574
    gegsy
    Well I can’t see it for one 😉
    Usually all hinges on a problematic cavity are changed as the norm.
    I can only guide and suggest 😀
    bigyin
    Ok fair enough… thanks very much for you help
