Home › Forums › Public Support Forums › General Enquiries And Questions › Appliance recommendations
- This topic has 6 replies, 4 voices, and was last updated 20 years, 11 months ago by
admin.
May 14, 2005 at 4:05 pm #9573
KeymasterI have a budget of around £1200 (it may stretch a little more though!) and I need the following:
Dishwasher (60cm fully integrated)
60cm double built under oven in stainless steel
stainless steel hood 60cm
hob (electric)For the dishwasher, I’m pretty much decided on the Bosch SGV53E03 (for £379) but the rest I’m still undecided.
Any advice/recommendations?
Many Thanks.
May 14, 2005 at 6:24 pm #134664Martin
ParticipantRe: Appliance recommendations
msa wrote:hob (electric)
Stainless Trim maybe?
May 14, 2005 at 6:56 pm #134665Penguin45
If you’re going with Bosch for the d/w, you won’t go too far wrong sticking with them for the rest. Neff is also popular and Bosch made. Whether you can do it all in stainless as Martin suggests and stick to your budget is a bit debatable.
CDA is a fairly new name in built-in stuff and the cooking range is quite impressive. Do not buy their dishwasher though…….
HTH
Penguin45.May 17, 2005 at 12:54 pm #134666admin
KeymasterRe: Appliance recommendations
I’ve taken your advice and stuck with Bosch appliances. Needed to stretch the budget a little though! OK, so am I safe with these choices:
Dishwasher SGV53EO3GB @ £374
Double built under Oven HBN13N550B @ £603
Hob PKE615CO1E @ £334I’ve shortlisted a couple of other slightly cheaper ovens too. Are these worth considering:
Electrolux EOG6335X @ £543
CDA708 @ £473You get 2 years warranty with Bosch so I suppose it’s worth paying that little bit extra?
I haven’t looked at hoods yet but I’m after one for < £200. 60cm Chimney in stainless steel. Any ideas?
Again, cheers for your help. 😀
May 17, 2005 at 1:13 pm #134667don
ModeratorRe: Appliance recommendations
Hi msa
All great choices IMO.
Stick with the Bosch for continuity of look and the build is good too.Try the DHU635A 60cm chimney.
Don
May 18, 2005 at 12:18 pm #134668admin
Thanks don,
Just about ready to order but noticed a slightly flashier bosch hob. Looks like it has nicer controls. Is it worth spending an extra £80 and going for the PKE645EO1E instead?
Cheers guys. Great site, very useful. I’ve recommended to other people. It’s nice to be able to get some independent advice.
Mark
May 18, 2005 at 1:00 pm #134669don
msa wrote:Thanks don,
Mark
Hi Mike
Hob has the same technical spec. The PKE645E01E has touch controls, which makes it easier to keep clean and gives a nice flush look. £80 difference? I would say good value for money.
Thanks for the recommendations :tup: . We aim to please 😀
Don
