Re: Aqua Stop Hoses
The idea of the aqua-stop being mounted vertically is to ensure if there is any leakage from the isolator tap or the rubber seal, the water runs down into the aqua-stop & then into the machine (to shut off the appliance to stop further use & alert the user of a problem/leak). If the aqua-stop is mounted horizontally, any leakage can leak out without the water going down the outer hose & into the machine & therefore not alerting the user of any faults or leakage. It doesn’t make any difference electrically/mechanically which way its mounted, it just effects its intended function. Hope this makes sense.
