hi just repaired this model ie new belt and pulley now wont heat, its not the normal type
there is no heater under back cover does anyone know where the stats are located thanks John
Can’t actually see any stats on parts diagram, only a sensor strip which is part of the door surround and two thermistors, one in the front and on which appears to be on the top of the heat pump unit. ????
Never seen one but I would imagine that ntc failures should throw up an error code.
