Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Aqualtis AQ113D697E constant pumping out
- This topic has 7 replies, 3 voices, and was last updated 13 years, 6 months ago by
a1al.
October 10, 2012 at 7:49 am #71886
a1al
ParticipantHi everyone
Been out to this washing machine it would do nothing but pump out.
I changed the main module and it done a 30min quick wash while I was there. Customer rang next day to say that it was only pumping out again.Any ideas anyone??
Alymer
October 10, 2012 at 7:52 am #382690a1al
ParticipantRe: Aqualtis AQ113D697E constant pumping out
Sorry meant to mention that it does not show any fault codes that I can see.
ThanksOctober 10, 2012 at 9:47 am #382691Muv
Sounds like it could be a dodgy pressure switch
October 10, 2012 at 1:22 pm #382692a1al
Hi Martin
Does a new pressure switch need to be reset as I’ve read in some posts?
AlymerOctober 10, 2012 at 2:28 pm #382693Muv
I’ve never had to do the reset procedure after putting a new switch in…I think that’s only applicable if you have had to clean out the filter/pump, and the machine has been layed flat down on either its back, or sides, this lets water run up tube and in to switch…
Or so I believe….unless anyone knows different?
October 10, 2012 at 2:37 pm #382694madangler1
Has it got the linear pressure switch ?
If so it thinks there is water in it. Iv seen these pump for about 45 minutes then throw F05. But if it was not left that long no error was shown.
Did you check the sump? One had a blockage (sock) in the sump. In the other a cable tie manage to float up into the pressure hose rite at the bottom.
October 10, 2012 at 6:01 pm #382695a1al
What do you mean by a linear pressure switch?
The one fitted to this machine is blue in colour and has 4 wires connected to it by edge connector.October 10, 2012 at 9:07 pm #382696madangler1
Yep that’s linear switch, measures actual water quantity via pressure rather than just a set level.
I would check the sump and pressure system then perform a reset as per HP method
