Aqualtis AQ9D6921UKV Just Pumps
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Aqualtis AQ9D6921UKV Just Pumps
  • #74901
    jag-12
    Have the above machine which as soon as a program is selected just sits and drains. Counts down on the display but nothing else happens.
    All connections checked and component insulation checked.
    Changed linear pressure switch and tried the reset procedure.
    With the pressure switch disconnected the pump does not run.
    Does not give any error codes
    On a couple of occasions when fiddling with the pressure switch and its connections the machine sprung to life and filled.Ran normally However when it drained as part of the cycle it then just sat pumping again.
    Any ideas guys ❓
    #393188
    madangler1
    Re: Aqualtis AQ9D6921UKV Just Pumps
    I have seen a few problems with the linear pressure switch models that get stuck on pump out, only way Iv found to reset is reprogramming the module.
