Aquarius FDPF481 Not Heating/Washing Properly
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Aquarius FDPF481 Not Heating/Washing Properly
  • #89016
    sidewinder25
    Program will start fine as normal and on a daily wash of 60 mins once the counter gets to 56 mins left it will all of a sudden drop to 30 mins remaining, The cycle will continue to finish but there is no heat to the water and the plates are not dry or hot at the end of the cycle. Does this mean just the element is goosed or is it the pcb?. No fault codes are evident
    #440065
    Re: Aquarius FDPF481 Not Heating/Washing Properly
    could be either.
    you would need to access the element and check its resistance to find out if its ok
    sidewinder25
    Thanks for the quick reply. Ill check it and what should i expect to see
    #440067
    sidewinder25
    element is open circuit so time for a new one
