Aquarius noise
  • #41156
    vwtone
    Hi all
    Hopefully someone can give me some advice, I have an Aquarius CTD00 drier that makes an awful noise. I have narrowed it down to the condensor which I feel is vibrating in the housing, I remove it and it is quieter. Does anyone know of a fix or mod that I can carry out and watch the football in peace?
    Thanks in advance.
    #268971
    Re: Aquarius noise
    I have never heard of a condensor causing noise, 😕 perhaps the Indesit/Comet lads may have come across it.
    The two fans do have a habit of coming loose, these do make a noise.
    There was also a problem on earlier models. The front of the drum was seated on two large plastic pulleys which made an awful noise. These have been superceded by reverting back to the four small bearing pads used on Creda dryers for the past 30 years. :rolls:
    helo_75
    its the front fan
    when you take the condenser out, theres less resistance to the airflow, thats all.
    part number 1703002 from online store
    #268973
    helo_75
    http://shop.ukwhitegoods.co.uk/Tumble+D … r+Fan.html
    bargain price
    BUT, as jim says, if its over 2 years old, then u need to check the drums run on pads, not wheels
