Aquarius wt540
  • #51873
    shunt01
    We have an Aquarius WT540 washer.
    The problem is that the machine does nothing when the start button is depressed.
    When first switched on and program selected the lights all come on momentarily (always has) when they go off the appropriate program options are selected and the associated lights come on.
    When the start button is pressed the program light such as spin or ‘E’ comes on as well as others but the door locked light does not come on although the door is securly locked.
    Can anyone advise what the problem may be? The machine is 4-5 years old.
    #309639
    don
    Re: Aquarius wt540
    Moved you into the washing machine help and support forum 😉
    Don
    #309640
    Re: Aquarius wt540
    Could be worn motor brushes, failing that it is likely to be yet another Indesit PCB failure.
    #309641
    Re: Aquarius wt540
    Start switches fall off the pcb with surprising regularity….
    helo_75
    only it wouldnt lock the door if the switch wasnt there
    carbon brushes, every time
    #309643
    Re: Aquarius wt540
    You are wise, Master Helo…. 😀
    :p45:
    #309644
    Re: Aquarius wt540
    Hmmm..I know nothing Master. 😉 😛
