Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Aquarius WT540 and flashing lights problem
- This topic has 8 replies, 3 voices, and was last updated 15 years, 3 months ago by
broadpaws.
December 23, 2010 at 11:01 am #59766
broadpaws
ParticipantHi guys – my washing machine is playing up – just in time for crimbo.
basically it will not finish a cycle and we get lights 2 & 4 (reduced crease & mini load ) + on/off flashing.
if i turn power off then on i can select a spin and it will finish – but looks to be lots of water being spun out.
suggestions on fix welcomed.
cheers
darranDecember 23, 2010 at 4:54 pm #339548iadom
ModeratorRe: Aquarius WT540 and flashing lights problem
Its possible you have a blockage.
The first place to look, after you have removed the mains plug is inside the large black sump hose located behind the small, lower back panel.
Have a few towels handy and make sure you keep the water of the components.
December 23, 2010 at 6:44 pm #339549broadpaws
ParticipantRe: Aquarius WT540 and flashing lights problem
Thanks for the info, i will try that, i have had a blockage in the pump ❓
thing at the front/bottom r/h/side.
let you know how i get on
Darran
December 23, 2010 at 8:06 pm #339550iadom
Ah, its the dreaded sealed drum model. What you actually have is a WT540/1, the full model number makes all the difference. 😉
Worth making sure you don’t have some frozen pipework as well.
50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of my washing machine calls in the past two weeks have been due to the weather, mainly in garages but several frozen up inside the kitchens.
December 23, 2010 at 10:41 pm #339551broadpaws
oooo ruddy hell – you know the variant from that rough description
8) 8) 8) 8) 8) 8) 8) 😆w/m safefy inside house next to dish washer and thats okay and we didn’t get that cold over here in Norfolk -8 ( one night only ) last week.
will get the tools out tomorrow morning
Darran
December 26, 2010 at 3:13 pm #339552broadpaws
Okay – found the blockage its at the end of the black pipe and into the pump housing – a lovely selection of coins – 3 £1 – 5 2p’s 4 pennies and 3 10p pieces combined with a golf ball size of fluff/material – half of which was wrapped and the bit that unscrews from the front of the m/c
i will need to source a new part as it was in tight and the thread was difficault to unscrew it broke.
cheers for the help
Darran
December 26, 2010 at 3:36 pm #339553broadpaws
hmmm, cant seem to find this pump filter part, any1 have a link ?
Darran
December 26, 2010 at 6:53 pm #339554helo_75
Participantfilter isnt listed as a seperate part for that (which would explain why u cant find it)
pump complete however is c00145315
there is a part number for a generic filter kit, with 4 or 5 filters in there, but is as expensive as a new pump
http://shop.ukwhitegoods.co.uk/Washing+ … +Pump.html
is what you require
and by the way, it wouldnt have broke if youd taken the pump off, and removed the pump back.. thats the easieast (and, aparantly , cheapest) way to do it!
good luck
December 26, 2010 at 7:04 pm #339555broadpaws
What a bummer………….. 🙁
typical ! got the model where you can’t get individual bits.. :rolls:
thanks for that Helo
now, wheres that credit card…..
Darran -
