Aquastop Hose
  • #52681
    ray.t
    Been to a miele machine with one of these hoses that wont take any water in. Does anyone know if these hoses let water through if you connect one end to the tap and turn it on and put the other end of the hose into a bucket etc.
    Thanks, Ray
    #312730
    washermanuk
    Re: Aquastop Hose
    no matey 😥 needs the valve to be energised
    #312731
    clayside
    Re: Aquastop Hose
    Some aqua valves in series with coil on inlet valve ie each coil 120 volt. so beware 😯
    #312732
    ray.t
    Re: Aquastop Hose
    Do you know if the machine will work with a normal fill hose?
    #312733
    washermanuk
    Re: Aquastop Hose
    Been thinking about this 😉 I have fitted a normal fill hose to these before? but u need to do something with the block connection to the aquastop valve from the other fill valves under the lid!!! Long time since i done this but i think i just linked them accross to complete the circuit otherwise the machine senses no fill and the inlet light will flash.
    But i must stress i really cannot remember so dont just take my word for it 😳
    If anybody has ideas or done anything similar?
    #312734
    ray.t
    Re: Aquastop Hose
    I have fitted the hose to the machine and at first it did take in some water and I thought all was ok.
    Since then the machine will only work on spin or drain and the machine wont take in any water, but the check water light is not lit?
    Anyone else know if I should just bridge the aquastop connection?
    Ray
