Showing my ignorance here,
Are all NTC’s rated the same and are they interchangeable subject to connections.
Have fault on heat pump dryer and would be good to eleminate posable causes for longer drying times. 8)
They can use different resistances in much the same way that thermostats use different temperatures. Many are the same or similar but you can’t know for sure most of the time.
