Are Indesit taking the widl!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Are Indesit taking the widl!
  • #29354
    reaper
    These are doing my head in.3 m/cs in a week.
    1.Wd10 fills up on wash does 5 mins and starts clicking – 15 flashes says a fault with drier probably the pcb.Drier and fan motor are red hot but everything checks out on the unit.Drier cycle and spin cycle work fine.Fit pcb from EMW fault still there – argh!
    2. Ariston W125 clicking round 10flashes – pressure switch fault-fitted one fault still there – argh!
    3.WID102 – Filling and emptying 3rd and 4th lights flashing and the last wash used boiled(or got too hot) Faulty ntc indicated,fitted one – no joy-ARGH!
    Might as well wipe your bum on these error codes. The fault when, or if you find it is usually unrelated.I think the only things worth doing on these m/cs are blocked pumps and door handles -trouble is I’m too damn curious and its costing time and money,any clues please?
    #222853
    Bill
    Re: Are Indesit taking the widl!
    Grim reaper 😆
    Bill Ellis :scot:
    #222854
    cessna
    I work for them and i hardly go by the fault codes they throw up.
    Most of the time it will be the board at fault.
    #222855
    roly16
    The guy at EMW recommends always checking the motors/brushes before changing the boards. Also check that the heater wires aren’t breaking off at the heater terminals. Had one once where they were partially broken; only found it when they finally broke off with a puff of smoke.
