I have an Ariston built in oven and one of the hinges has come away from the oven and the door is hanging loose how do i repair it
any help will be greatly appreciated
Is the hinge actually broken or has it just come adrift.
The user manual should have details of how to remove and refit the door assembly.
If it is broken the you would be advised to fit 2 new door hinges.
There are a few different hinges used on these so exact model number ( there is no A2011/12 ) and if possible full serial number and commercial code needed to ID correctly.
