ariston A1124uk
  • #16385
    bigjag
    The washer works but when you put it on a wash it keeps going and doesn’t move on to the next bit just goes round oh i have cleaned the filter out
    can you help cheers
    #169623
    Dave_Conway
    Re: ariston A1124uk
    Does the drum reverse direction or continually rotate in the same direction ?
    #169624
    bigjag
    Re: ariston A1124uk
    no it goes both ways 🙁
    #169625
    Dave_Conway
    Re: ariston A1124uk
    It sounds like the PCB in that case 🙁
    For a definite diagnosis, check the repairs@ link below for an engineer 🙂
    #169626
    bigjag
    Re: ariston A1124uk
    pcb? is it a big job and is it worth it ?
    and thanks for your help
    #169627
    johnnyj
    Re: ariston A1124uk
    Sounds like a heating fault broken wire or open circuit heater
    #169628
    Re: ariston A1124uk
    Hold on a mo….. You say it “just goes round” – do you mean the timer knob constantly rotating? If so, run the machine again, wait for it to fault (knob clunking round) and count the flashes form the power lamp. It may well go 1-2-3-4-pause-repeat for instance. Give us the count and we may be able to be more precise with a diganosis.
    bigjag
    Re: ariston A1124uk
    it dosn’t go to the fault bit with the timer turning.
    say if it was put on a 4 wash it stays on 4 and dosn’t move to the next bit of the wash and it will stay at that all day 🙁
