Ariston A1200WD eeprom
  • #24881
    Fairdeal
    Hi Guys
    I went to look at the above machine and the lights were flashing.
    The first error was the first and the 2nd light was flashing(F12).Looked at the code and it was “Check wiring & terminals”.Checked all of them and switched it back on and then 1st and the 3rd(F09).Eeprom error
    My question is;
    How did eeprom go and by changing just th eeprom do you think it will cure it?
    Regards
    #203654
    Re: Ariston A1200WD eeprom
    Chances are it wont cure it and unless the board has already been replaced at some point, the EEprom will have been soldered in. Not impossible to change but not easy either. Would recommend board and eeprom together. Assuming that is the problem. Check ntc wires for odd and varying faults on these.
