Ariston A1235
  • #59372
    aqua_serve
    Guys,
    Went to this machine on Saturday, machine turns on, you select any cycle and the door locks, nothing further happens, there are no fault finding LEDs giving me any further information.
    Could it be the Indesit module or am I missing something far more simple?
    Mark
    #337961
    cornwell40
    Re: Ariston A1235
    Have you checked the carbons??
    TC
    #337962
    aqua_serve
    Re: Ariston A1235
    As it happened I haven’t, I didn’t expect that this would be the problem on this machine, probably showing my inexperience but I’ll head over tomorrow!!
    I appreciate your advice,
    Mark
    #337963
    Re: Ariston A1235
    Its a good rule of thumb with most modern washers without obvious faults, check the brushes and megger the heater. 😉
    #337964
    allan73
    Re: Ariston A1235
    And don’t forget to pull on the wires at the motor 😉
    #337965
    aqua_serve
    Re: Ariston A1235
    Thanks for the help guys, still no luck in terms of testing, I’ve double checked the brushes, element all connections and not getting anything when setting any cycle.
    The guy is only just back from a business trip so no major panic but with Xmas and the post being as it is I think my only way is to send the board off for analysis, do you agree?
    Mark
    #337966
    allan73
    Re: Ariston A1235
    Have you checked the motor toc ?
