Hi all, this machine has stuck on a fault causing it to fill and pump at the same time. I had one afew weeks ago and fixed it, but I can’t remember what I did!. This model has two vertical rows of four lights in each, the left hand ones are wash status L.E.D.s, the right hand ones are incorporated into the option buttons. When the fault occurs the bottom two option buttons flash along with the on/off light. I’ve checked the fault codes in the new handbook, but I can’t see anything that matches this fault. I’d be grateful for any help, cheers.
