Ariston A1400SWD – Pulsing on fill and overfilling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ariston A1400SWD – Pulsing on fill and overfilling
  • #73966
    gadgetdad
    Hi Guys,
    need help with this machine – select a cycle, starts ok but inlet valve appears to pulse, prog lights flash randomly as does the lock light – removed all earths, swopped pressure switch, cleaned connectors on pcb etc etc. Finally got pulsing to stop but machine then overfills – or at least it would have done if I hadnt stopped it.
    Any ideas my dears
    gadget
    #389458
    madangler1
    Re: Ariston A1400SWD – Pulsing on fill and overfilling
    I think that’s an indesit evo 2 electronics. It’s motor related normally with those symptoms. Check brushes,motor, motor harness and finally board. I normally find its either the brushes or the harness but can be any of the four that cause it to do it.
    #389459
    gadgetdad
    Brushes ? really ? I’ve never seen that before but how to superior experience and knowledge.
    Pop back and let you know what I find – thanks muchly.
    #389460
    madangler1
    Well the original pulsing symptoms are normally motor related.
    As for it now over filling and the pulsing stopped of start from scratch and make sure the pressure switch is wired correctly ect.
    Edit. Just checked its a 535 evo 2 board so as I said do with motor area first
