Ariston A1400WD Washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1400WD Washer dryer
  • #74715
    BarkbyThorpe
    Hi All
    Looking for some HELP with my washer dryer.
    I loaded up and switched on this morning to be presented with what I presume is an error code and no start. Lights 1 & 2 (delay timer and super wash) along with the door lock were all flashing in quick succession. After about half an hour of this condition, the machine, hesitantly at first, suddenly burst into life and completed the wash cycle. Its the first time its let me down but looks like a problem is arising. Could it be filters want cleaning?
    Any HELP or ADVISE very much appreciated?
    Many thanks
    Regards
    Mick
    #392635
    Re: Ariston A1400WD Washer dryer
    1&2 signifies a communications error. Often due to loose connections between the two modules. You need to remove the mains plug and tighten (squeeze) the connectors carefully.
    #392636
    BarkbyThorpe
    Many thanks for that info
    Much appreciated
    Can you advise are these pcb/connectors easily accessible?
    #392637
    The one behind the facia at the top is, the one in the base at the back is not.
