Ariston A1435
  • #11025
    Hi I wonder if someone can help I have an Ariston A1435 it seems to have went wrong in the middle of a wash all it does now is start to take in water then after a minute or so it starts clicking through the dial the model number is LB2000C.Thanks
    #143659
    Re: Ariston A1435
    If you count the pattern of the flashes from the on/off lamp when it faults, this will indicate a fault code – ie 1,2,3,4 pause, repeat.
    Please post this info and we should be able to advise you.
