ariston a1436 f10
  • #39540
    dealdd
    hi there been out to this machine a few times now have changed board, pressure switch and pressure hose. checked all plumbing sump hose and filter and also checked valves an heater. found that the motor is getting very hot. does any one have clue what to do next ???
    #262741
    Re: ariston a1436 f03
    Only part you’ve forget to check is that which is giving error…. Temperature sensor= F03 😈
    #262742
    dealdd
    Re: ariston a1436
    no sorry is giving error f10 the first and third lights are flashing
    #262743
    helo_75
    f10 is not sensing pressure switch
    usually switch or board or wiring
    #262744
    roy1
    Re: ariston a1436 f10
    Open up the plug to the pressure switch, had two machines in
    the last week where the cable had burnt.
