Ariston A1535 stuck on program, wont advance,
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1535 stuck on program, wont advance,
  • #27683
    s_mit
    Ariston A1535 stuck on program, wont advance, when moved manually returns to the program I started it on.
    Firstly the fault was that the was had not spun, so I emptied the the filter at the bottom of the machine to find a number of coins! The water supply is working and the Machine was turning, but not now.
    Also no error lights noted as yet!
    Any help appreciated guys. Thanks in advance. Shaun.
    #215189
    s_mit
    Re: Ariston A1535 stuck on program, wont advance,
    Just moved dial to spin to get 3 very quick flashes then both lights stayed on…….dunno if this adds anything usefull?
    #215190
    If you move the control in the middle of a programme the dial will click right round to its original setting. You have to turn the control knob to one of the Off/Reset positions, wait for the mains neon to flash, switch off, then you can set the control to a different setting.
    Do this then set it to a programme and make a note of which neons are coming on by number from left to right when, or if it fails to work.
    s_mit
    OK guys, think I have found the problem! After tapping the brushes on the motor the machine started moving again!!!
    Guess that means brushes or armature wear.
    #215192
    Change the brushes ASAP, arcing brushes can sometimes damage the main PCB if you keep trying to run the motor.
