Ariston A1600WD belt fitting
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1600WD belt fitting
  • #19197
    Hagsy
    Hello,
    The belt has slipped off of my Ariston A1600WD, I managed to get it back on but it fell off again. I didn’t notice any tensioning devices or ways to release the bottom motor. Does anyone has any experience of this make/model. I have lost the manual which doesn’t help.
    Thanks,
    Craig.
    #182131
    Re: Ariston A1600WD belt fitting
    This is a Hotpoint based machine. There is no adjustment, the belt is a ‘stretchy’ belt. If it keeps coming off and the drum is smooth and quiet when you turn it and there are no rust marks on the chassis behind the lower back panel then you need a new belt. The manual you will have is a user manual, it is not a service manual so would be of no use whatsover in this instance.
    PS. If you managed to get the old belt back on yourself that would suggest that it is too slack. A new belt would be very, very difficult to get back on without the expertise required. 😉
    #182132
    Hagsy
    Thanks for your reply. How should I get the belt back on. I put it on the bottom grooved motor and half onto the drum, then turned the drum till it was full on. Did I stretch the belt in this process?
    #182133
    Hagsy wrote:Did I stretch the belt in this process?
    iadom wrote:There is no adjustment, the belt is a ‘stretchy’ belt
    #182134
    Hagsy
    Ok, stretchy belt…got it. How does it go on or is this a trade secret never to be revealed??
    #182135
    Hagsy wrote:Ok, stretchy belt…got it. How does it go on or is this a trade secret never to be revealed??
    The trade secret is to use a cable tie to fix the belt onto the drum pulley, rotate the drum til the belt fits fully – then cut the cable tie off….!
    Ssssssssssssh….don’t tell anyone! 😀
    #182136
    Hagsy
    Ingenius…don’t worry, I’ll take that to the grave with me.
    Thanks for your input…Excellent site!!!!
    #182137
    kiddo66
    you dont need to cut it just continue to turn drum and cable tie snaps
