Ariston A1600WM washing machine flashing lights
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1600WM washing machine flashing lights
  • #73785
    oxgoldilox
    I have tried without success to find the ‘meaning’ of this sequence of lights, so I hope someone might know on here:
    Wash cycle starts, water is drawn in, then the following lights flash. Apart from the door lock, the other three flash in time to each other. There are no pauses.
    Door lock on rapid flash
    Column 1 (of four buttons): 3 (spin) and 4 (dry)
    Column 2 (of four buttons): 3 (reduced spin)
    Is there any hope for getting my washing done today?!
    Many thanks.
    #388788
    oxgoldilox
    Re: Ariston A1600WM washing machine flashing lights
    Anyone? Would be so grateful… 🙂
    #388789
    I’m guessing it is actually an A1600WD, there is no A1600WM.
    I don’t have the error codes for that machine but it is usually only one row of lights used for error codes on that range of machines.
    Hopefully someone who does have access to the exact codes may be along later. 😉
    #388790
    oxgoldilox
    Many thanks! You’re absolutely right: it is WD, not WM (I’m guessing WD is Washer/Drier). Today I tried to run other programmes including a spin and a dry cycle – both triggered the same code.
    #388791
    Hmm, the nearest I have found that uses both columns only uses the bottom light of the left hand row and a combination of all four of the right hand row which are actually buttons. 😕
    Looking at the parts list for your machine also shows a row of lights on the left and a row of buttons on the right.
    #388792
    iadom wrote:I don’t have the error codes for that machine but it is usually only one row of lights used for error codes on that range of machines.
    Are’nt they the same as the WIDL codes Jim? (F03 NTC error perhaps?)
    #388793
    Not AFAIK, the machine is based on a Hotpoint chassis, the A1636 series uses the same bank of four left hand lights and four right hand buttons but only the bottom (4th) left hand light and the four, right hand buttons are used for the codes.
    #388794
    oxgoldilox
    My apologies again – the left hand column is indeed just lights. The right hand column are buttons you can use to select programmes. But the lights I originally posted about haven’t changed… 😕
    #388795
    Well until someone can confirm that the A1600 and the A1636 do use the same codes we are snookered. And if they do it still presents us with a problem as that would then mean you have a spurious error message. 🙁
    #388796
    oxgoldilox
    Well not too keen on the possible snookering, but like the fact that I have a spurious error – excellent word! 😆
    All help gratefully received.
    #388797
    The only way to proceed without the error codes is to remove the mains plug and then visually and electrically check each component with a suitable megger or multimeter.
    #388798
    oxgoldilox
    Thanks for all your help anyway. I’ll deconstruct the machine bit by bit to see if I can isolate the problem. Could it be something as simple as a blocked waste pipe? Or does this really point to faulty electrics?
    Thanks again.
    #388799
    A blocked outlet hose would leave the machine full of water and flash a known error code (hopefully)
    TBH anything is possible, the Indesit electronics in this machine can be a bit flaky. 🙁
