helo_75 wrote:oh, and its worth making sure the connections on the pcb are ok too.. plug out of course
Thanks, i’ve just found this:
F10: No full and empty signal
• Check the efficiency of J3 connector contacts on the card
• Check pressure switch status checking J3 wiring connector pins:
– 2-4 ohm continuity – tub empty
– 2-3 ohm continuity – full tub
– 2-1 ohm continuity – tub overfilled, at least halfway up door glass
• Check wiring of connector J3/Pressure switch
• Replace Pressure Switch
• Replace Card.
As its the second time the machine has packed up within the last couple of months and its over three years old now so thinking of cutting my losses to be honest, but before i do what would the cost of parts be? I’m really useless with electronics so its a bit daunting.
