Ariston A1635UK – door lock light always on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1635UK – door lock light always on
  • #24737
    ellipses
    My 3 year old Ariston A1635UK has suddenly developed a fault. When I push the power button all that happens is the door lock light comes on – regardless of whether the door is open or closed. Furthermore, the door is not locked…
    I thought (from reading an old post on here) that this could be the door interlock – so I took that out and tested the switch, which seems to be working fine.
    Anyone have any other ideas I could try before calling out the engineer?
    Thanks in Advance
    #203121
    Re: Ariston A1635UK – door lock light always on
    In what sense is the door lock OK? Does it actually lock the door? How did you test it?
    ellipses
    It doesn’t lock the door – but I tested the switch was working with a multimeter.
    #203123
    Did you get a high resistance between two terminals and zero to the other?
    it could be the carbon brushes have worn out in the motor when they go open circuit the machine will do nothing on that model
    tony
    allways isolate machine before testing 😯
    #203125
    ellipses
    As for testing the switch – yes that’s what I got – and it changes when the switch is switched.
    If it’s the carbon brushes – that’s probably beyond my rudimentary skills to fix, but is there an easy way to test that?
    Many thanks for your replies so far.
    #203126
    it does mean taking the motor off and checking for continuity between the carbon brushes but if your not sure click on repairs@ for a local engineer its usually quite a cheap repair approx 50 to 60 squid inc parts and labour 😀
    tony
    #203127
    ellipses
    Thanks for your help guys – I probably will click on the link.
