Machine aborts after about 30 seconds with top option light flashing. I read this as aF08 – heater relay. Changed the board with a recon from EMW – same fault. Where am I going wrong guys?
Checked heater for continuity and insulation – both ok. Accidentally left the ntc plug off, and when I tried it, I got lights 3 and 4 lit. Put it back on and it reverted to the usual light 1.
Pressure switch is a likely candidate. Take old one off and prise it open with flat screwdriver(s), taking care not to get blood everywhere. If you find contacts are burnt a bit, clean them up, reassemble to see if that works and if so, order new p/sw. Alternatively just try in a new p/sw.
Mike.
