Ariston A1636 fails on drain cycle?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1636 fails on drain cycle?
  • #34297
    Adwill
    Hi All,
    I have an 18 month old Ariston A1636 which has developed a fault where it stops when it is time to drain. I have spent a couple of days searching the forum and trying out what previous suggestions have been given but still no good.
    Lights flashing are 2 + 4 (1 being top/4 bottom) when fail take place.
    I have checked the filter at point where water exits the drum and there were a few coins present which have been removed. Checked all other tubes/components relevant to drain and pump but nothing is obviously out of the ordinary – no kinks etc.
    Any help much appreciated.
    Thanks,
    Andrew
    #242089
    Re: Ariston A1636 fails on drain cycle?
    2+4 – pressure switch reading full after the time allowed.
    Have you actually pulled the pump and inspected inside the chamber? Objects do get through the filter. If the machine is coupled to a sink spigot check that as well.
    Adwill
    Thanks Penguin.
    It does appear to be the pump was blocked. A piece of plastic had passed the filter and was sitting inside the pump.
    Thanks for your help.
    Andrew
