Ariston A1636 no fast spin
This machine will fill, wash, heat, drain turn slowly on the spin then I get the top one of the four vertical LED’s flashing along with the start one in all the info I have for this machine this is f08 “heater relay stuck or pressure switch jammed full “as I said it fills and heats ok it only when it tries to spin I get the fault. I have checked the pressure switch all seams ok.This machine has the brush less motor.
Any one got any suggestions please.
Thanks Bernie
