Ariston A1636 no motor.
Viewing 1 post (of 1 total)
  • #43166
    aqualectric
    Ariston A1636 washer. 31294. 39181229.
    This machine fills, then waits 15 – 20 seconds then pumps out and flashes the lowest lamp in the middle of the fascia (rinse hold IIRC). The door lock lamp flashes rapidly too. This one has the induction motor and inverter board fitted; checked the PCB and the motor wiring but no motor action at all on any program. Door locks and unlocks, I’ve checked the heater and there are no blockages in the sump or pressure system. It fills to level and stops. It’ll drain quickly and completely. 😕
    I can’t find a fault code description in the book, so if anyone can point me in the right direction, I would appreciate it.
    Thanks,
    Steve.
