hi when washing it goes through the cycle, but half way through it stops with superwash and rapid flashing constantly . then have to take some out and put on a spin .any ideas please
thanks
ps nowflasing both lights when tried on spin
They should be flashing, none should be on steady. however 2 + 4 indicate that pressure switch is stuck on full. you may have something blocked in the sump under the drum. It is in the large black rubber hose that comes from the drum to the pump. Please remove mains plug if you intend to have a look, a few towels on the floor may be a good idea as well. 😉
