Ariston A1636 top light flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ariston A1636 top light flashing
  • #65527
    Mark1
    Jjust been to this washer which was not draining. (blocked filter) cleaned it, it stasrted off ok but after a minute or so, it stops and the top light in the column starts flashing and you are unable to turn the macnine off (except at the plug)
    cheers Mark
    #360867
    Criscold
    Re: Ariston A1636 top light flashing
    I think this is error F07 – Heater relay stuck – could also be caused by pressure switch sticking
    Colin
    #360868
    johnnyj
    F08, could be press sw, or faulty module but i would check the element 1st, had lots giving this fault if the heater is down to earth, especialy if the sump was full of coins,
