Ariston A1636 Washer – Fault Code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ariston A1636 Washer – Fault Code
  • #26549
    grooster
    I’ve just been out to this Ariston washer A1636. It has two vertical rows of four light in the centre of the panel and the bottom 2 on the right hand side start flashing after a couple of seconds on any programme.
    I’ve looked on the error code section but cant seem to find the codes. The nearest i think is the WIDL indesit machines but i’m not too sure.
    Any help would be greatly appreciated.
    Cheers
    Nick
    #210562
    Re: Ariston A1636 Washer – Fault Code
    Same as WIDL. 3+4 = F03 NTC fault, could be NTC, or broken/loose wiring etc.
    grooster
    Thanks for the quick reply. I havent had a proper look at it yet but is the NTC seperate on this or is it built into the pcb.
    Nick
    #210564
    NTC is the heater temp control, it will be inserted into the heater itself. If that checks out then you need to check for poor contacts on the Main PCB, then it starts to get really difficult. 😥
