Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston A1636 Water Leak
- This topic has 11 replies, 4 voices, and was last updated 18 years, 9 months ago by
StuartP.
July 11, 2007 at 5:59 pm #28921
StuartP
ParticipantDear All,
It appears that our washing machine is leaking water, having placed a sheet of newspaper under the front of the machine, it appears that the water appears during the spin cycle, and only at the front of the machine, it’s almost like it’s being spun out of the door seal ?
Any pointers gratefully received.
Stuart
July 11, 2007 at 7:43 pm #220649Penguin45
ParticipantRe: Ariston A1636 Water Leak
Possibly quite correct. Check round the top of the door seal for holes.
July 11, 2007 at 10:13 pm #220650iadom
ModeratorRe: Ariston A1636 Water Leak
This is often caused by partly blocked sump hose, this Hotpoint based machine has a decent door seal that is not prone to leaking at an early age.
July 16, 2007 at 5:59 am #220651StuartP
Can you give me some pointers on where to look please ?
I’m happy to investigate further, obviously, power off before cover off.
Cheers
Stuart
July 16, 2007 at 8:09 am #220652Martin
StuartP wrote:Can you give me some pointers on where to look please ?
iadom wrote:This is often caused by partly blocked sump hose
July 16, 2007 at 1:57 pm #220653StuartP
And the sump hose is found where ? Is it simply the once coming out of the machine, at the rear, or is it internal.
Regards
Stuart
July 16, 2007 at 2:01 pm #220654Martin
StuartP wrote:or is it internal.
The internal one Stuart 😉
July 17, 2007 at 8:07 am #220655StuartP
Ok.
So give me something to work with 🙂 , Where abouts is it, any tricks to getting into it to check for bloackages ?
Just after some pointers.
Cheers
Stuart
July 17, 2007 at 9:43 am #220656iadom
The SEARCH facility is a wonderful tool if you use it. 😉
July 17, 2007 at 11:12 am #220657StuartP
Thanks, great if you know what search for, or what model’s have similar problems.
Cheers
Stuart
July 17, 2007 at 5:14 pm #220658StuartP
Dear All,
Managed to get away from work early. Screwdriver at the ready, I set about the task of gaining access to the sump.
Where I found , 2 socks wrapped round the ball in the plastic cage, several parts of zippers, and numerous buttons.
Re-assembled, and did a leak test with a rinse and spin, no water on the floor.
See how it fairs with a load of washing.
Thanks to one and all. Should keep the cats happy who share the utility room with the washer, and were getting a bit sick of damp paws.
Cheers
Stuart
July 17, 2007 at 5:26 pm #220659iadom
Its a good idea to use a ‘washbag’ for the very small items, also try to avoid overloading if you know you have such items in the wash load.
Glad you sorted it, sorry about the ‘Search’ post, can’t make it to easy for you though, can we 😉 8)
