Please can anyone help with part numbers for Bearings , spider and drum for this 14 month old model?. Is this a straightforward bearing job or yet another item for the scrapyard?.
Have you actually been out to this machine yet. At that age it should have the newer Rubena bearing seal fitted, I have yet to see a failure in this type of assembly so would be very interested if this is actually a bearing failure. Loose concrete balance weights are very common ATM.
Went to this job this morning, surprising what a noise a piece of chain in the pump makes!. Just shows that we must not let the customer make the diagnosis.
Thanks for your help guys.
