Ariston A1637 delay timer and door lock indicators flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1637 delay timer and door lock indicators flashing
  • #74546
    Washdisher
    Customer reports lights flashing and machine full of water.
    Fills and agitates, drains, rinses and spins ok
    Have not seen the error code, which was reported by customer and she doesn’t know when it starts to happen
    Continuity across water heater and about 21.7k ohms across heater NTC.
    Live test on 90 deg pre wash; about 80V between heater terminals and about 80V between either terminal and earth??
    Board fault of NTC or something else?
    Have left machine on a cold wash to see what happens.
    Thanks for any help
    #391970
    Re: Ariston A1637 delay timer and door lock indicators flash
    Which light by number from top down is flashing and which column, the left hand row of lights or the right hand row of buttons?
    #391971
    Washdisher
    delay timer – top of right hand row of buttons.
    #391972
    Washdisher
    BTW it’s now gone through a complete wash cycle with ‘no heat’ selected
    #391973
    Aggh, the dreaded 8 flashes fault. 😥
    F08 heater relay….. or just about anything else you can think of. :rolls:
    #391974
    Washdisher
    So, given that everything else seems ok, it looks like a PCB fault do you think?
    #391975
    And/or the pressure switch, wiring connections, etc, etc.
    I will not waste my time on any F08 fault, been out of pocket once too often. 😥
    Washdisher
    Ok, thanks for that
    Derek
    #391977
    Washdisher
    Machine now done a cold wash and a forty wash with no problems. I’m guessing wiring from NTC to board may have been the culprit – it certainly didn’t seem to be a very positive connection. Thanks for all your help Jim
