Ariston A1637 (LB2000TRF) Error Flash – What does it mean?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston A1637 (LB2000TRF) Error Flash – What does it mean?
  • #51249
    wmcnicol
    My Ariston washing machine is refusing to work.
    Error flashes as follows:
    Door Lock Led: Fast flash
    Rapid Wash Led: Flash.
    I have been unable to find a service manual describing the fault flashes. 🙁
    When started, will open water inlet for a few seconds – then close it. Then usually just pumps out. Pump continues to run after whatever water is present has been pumped out.
    Any ideas?
    Thanks,
    William.
    #307384
    Re: Ariston A1637 (LB2000TRF) Error Flash – What does it mea
    Motor problems. Check wiring for continuity and breakages. Check continuity through motor. Being an Indesit-based machine the problem is probably the pcb.
    Be warned – this machine uses a high speed three phase induction motor. As a consequence, the capacitors on the pcb may store a charge of up to 500v for a period of ten minutes after programme completion.
    Pulling the plug is not enough – you have to wait.
