Ariston AF300 d/w not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ariston AF300 d/w not heating
  • #6404
    Albert
    There are three stats, a screw in one by the element which is closed cct
    a white one and a blue one next to the sump which are both open cct.
    Does anyone know if this is their correct state ?
    Thanx for any help,
    Albert
    #117481
    Dave_Conway
    Re: Ariston AF300 d/w not heating
    The screw in one near the heater is described as thermostat safety 78 NC
    The other “two” are actually one part and is described as thermostat 50/62 NO
    So it would appear that they read OK.
    Timers are a common failure on these, pull all the plugs off and check for burnt terminals 😉
    #117482
    Albert
    Thanks Dave, I’ll check the tmer.
    Albert
    #117483
    Albert
    Cheers Dave,
    I checked the timer for any sign of terminal damage and there was none,
    popped a new timer on even so and the machine works fine now.
    Thanks,
    Albert
